05-30-2024 12:35 PM - edited 05-30-2024 12:36 PM
I have 2x r510 APs connected to a ICX switch that have been running happily for 3 years. However, recently one of the APs (the upstairs one) has gone to disconnected and will not rejoin the unleashed network. I have pulled the power on it several times, and still just comes up to disconnected in the unleashed dashboard and ioctl light just flashes. If I disconnect the current master, and leave just the disconnected one on, then it will eventually take over and come all the way up. But then if I add the other one back in, it wont join. I did a factory reset on the upstairs one, and saw that it came back with the config.me SSID, so I disconncted, plugged my main AP back in, let it boot all the way up, removed the old object for the AP from the unleashed dashboard, then connected upstairs AP back in, and back to square one. Shows disconnected in the unleashed dashboard and ioctl is just flashing.
Here is the output of get election
The local AP's ip address is 192.168.x.x, Election role is master, Fix role is NO, Debug level is ERROR, Prefer master is 00:00:00:00:00:00, Prefer Second master is 00:00:00:00:00:00, Dedicated Mode Enabled: NO
MacAddress IpAddress Role CfgID StaRate FreeMem MeshEna MeshNode MeshNodeType Model ActiveVer BackupVer SysTime BoardType UpTime LastSeen
34:20:xx:xx:xx:90 192.168.x.x member 1 57 320212 1 0 1 R510 200.15.6.12.304 200.14.6.1.203 0 r510-5-31-4bss [16 mins 15 secs] [Thu May 30 13:23:21 2024]
--> ICX[0]: MAC=dc:....:cc, IP=192.168.x.x, SysName=[ICX7150-C12 Switch]
80:03:xx:xx:xx:60 192.168.x.x master 22344 51 237392 0 0 0 R510 200.15.6.12.304 200.14.6.1.203 94609301 r510-5-31-4bss [23 mins 57 secs] [Thu May 30 13:23:22 2024]
OK
ruckus(ap-mode)#
Any suggestions outside of completely wiping and starting over would be appreciated!
