Unable to connect to R710 after factory reset
Hi I factory reset a R710 AP and when I rebooted it I got the configure.meXXXXX SSID which requires a password.
I can connect to the configure.meXXXXX SSID wirelessly using the serial number of the AP as password but that's as far as I can get.
Both green PWR & CTL leds flash on AP.
I am unable to connect to it using 192.168.0.1. via web browser.
IP Scanner detects it at 192.168.0.1 & open ports 22 & 443 andI can ping it..
Any advice appreciated.
Stephen
9 REPLIES 9
Hi Sandeep,
I reset to factory using CLI command and rebooted.
But AP is the same...
From PuTTY:
Ruckus R710 Multimedia Hotzone Wireless AP
Version: 114.0.0.0.1294
OK
rkscli: GET IPADDR WAN
IP Address: (dynamic, vlan 1), IP: 192.168.0.1  Netmask 255.255.255.0  Gateway 0.0.0.0
OK
rkscli:
How do I install firmware ?
Stephen
Hi Sandeep,
I've run the CLI instruction fw show all
rkscli: fw show all
<Control Info>
ipaddr:
file: R710_114.0.0.0.1294.bl7
MD5 : F1C066498CD733F77C94F961C43BD084
type: 0
local_file
current primary boot image is Image1
---------------<Image1 FW header>
Magic:        RCKS
next_image:   0x280000
invalid:      0
hdr_len:      160
compression:  l7
load_address: 0x42000000
entry_point:  0x42008000
timestamp:    Wed Dec 18 00:59:41 2019
binl7_len:    15928248
hdr_version:  4
hdr_cksum:    0x84D6
version:      114.0.0.0.1294    ( 114.0.0.0.1294 )
MD5:          F1C066498CD733F77C94F961C43BD084
product:      r710      (0)
architecture: 0
chipset:      0
board_type:   0
board_class:  0
customer:
Image Sign Type: Intermediate Signed Image(ISI).
Tail start:   0xf2ff60
---------------<Image2 FW header>
Magic:        RCKS
invalid:      0
hdr_len:      160
compression:  l7
timestamp:    Wed May  2 11:28:02 2018
binl7_len:    12687196
hdr_version:  4
hdr_cksum:    0x057C
version:      110.0.0.0.663     ( 110.0.0.0.663 )
MD5:          D906240EC4282ACEF948186EC184AF0C
product:      r710      (0)
architecture: 0
chipset:      0
board_type:   0
board_class:  0
customer:
Tail start:   0xc18f60
OK
Stephen
Hi Stephen, seems you are able to login via CLI so that is good.  If this is the case, can you not login to the AP via UI and browser to https://192.168.0.1 ?  this will allow an easier upgrade of the code.
From the CLI you can follow these steps:
#fw set control R710_110.0.0.0.663.bl7 [where the filename is the one you want to upgrade to]
#fw set proto tftp
#fw set host 192.168.0.10 [where the IP is the TFTP server address]
#fw update
These steps should allow you to upgrade the firmware via CLI using a TFTP server.  But i would try to login to the web management UI first and browse to the upgrade section - it will be easier.
eizens_putnins
Valued Contributor
Most probable reason of problems is corrupted firmware on AP. As far as you can connect to AP using SSH, from  Ethernet port or through recovery SSID, you are good to upgrade firmware and probably can recover AP.
I had experience when whatever you do,  you can't connect to AP using SSH or http, reset to factory didn't help, so AP was efficiently bricked and this required RMA. It doesn't happened with standalone image but with 5.1.xxx  vSZ image after upgrade from previous version. This problem was 100% fixed in the latest release.
eizens_putnins
Valued Contributor
As AP has life-time warranty, open case with Ruckus, support will either help to resolve issue or arrange RMA.
