01-29-2021 10:03 AM
Hi I factory reset a R710 AP and when I rebooted it I got the configure.meXXXXX SSID which requires a password.
I can connect to the configure.meXXXXX SSID wirelessly using the serial number of the AP as password but that's as far as I can get.
Both green PWR & CTL leds flash on AP.
I am unable to connect to it using 192.168.0.1. via web browser.
IP Scanner detects it at 192.168.0.1 & open ports 22 & 443 andI can ping it..
Any advice appreciated.
Stephen
01-29-2021 10:14 AM
Is it Unleashed?
Regardless, if you connect to Configure.Me SSID you should receive an address via DHCP on your client. Then would connect to the gateway IP available which is the AP.
Flashing PWR light means the AP did not receive an IP address from DHCP and so it defaults to 192.168.0.1. You can connect to this IP through the wired port. Connect your client to the switch and assign an IP like 192.168.0.10, then you can connect to the 192.168.0.1 address via CLI or Web UI.
01-29-2021 10:47 AM
Hi
thanks for prompt reply.
If I enter 192.168.0.1 into browser I don’t get web UI with Ethernet to 192.168.0.10.
Stephen
01-29-2021 11:28 AM
That's odd - can you successfully ping the 192.168.0.1?
If so, can you ssh in to the AP instead of HTTPs?
01-29-2021 04:37 PM
I reset to factory and rebooted but AP is the same.
I need to reinstall firmware ?
Stephen
