T750SE AP Dissipated Power
AFI
In order to make a proper installation for the T750SE, I need to know its dissipated power, knowing that it will be plugged in AC.
I could use the consumption power, but If i can get a more precise number it will be better.
3 REPLIES 3
vasanth_edward
RUCKUS Team Member
Thank you for contacting us via the RUCKUS Community Forum.
Could you please confirm if the power consumption information shared from the T750SE datasheet addresses your query?
Feel free to reach out if you need any further information.
AFI
Hi Edward,
No this isn't what I'm looking for.
I got an answer from my supplier:
  • T750 : 82.6 BTU/hr
vasanth_edward
RUCKUS Team Member
Thanks for the clarification.
Appreciate the update — good to know the BTU rating for the T750 is 82.6 BTU/hr. That should help others who might be looking for the same spec.
Let me know if there's anything else you're trying to pin down — happy to assist if I can.
