T710 / T750 thread positions & dimensions
GreensTheorem
I need to build a custom bracket for a T710 and T750 access point.
Could you please provide a drawing of the hole / threads positions on the back of the T710 / T750 access point as well as the thread specifications?
Thanks!
1 ACCEPTED SOLUTION
GreensTheorem
As Ruckus wasn't willing to help, I helped myself.
For anyone looking for those dimensions in the future:
The distance between the center points of the holes is 102x130mm
The threads are UNF 1/4" - 28
Pictures of the brackets:
3 REPLIES 3
GreensTheorem
Hi @Ayush_Tripathi
Those PDFs do not contain any drawings or specifications.
I can measure the positions myself, but that's more error prone, so if you could please be so kind and send me a drawing with the position and dimensions of the mounting holes on the back of the T710 and T750 AP?
Thank you
GreensTheorem
