Spanning Tree Problems with Access Points connected to Procurve Switches
simon_eng
Anyone ever find switchports flapping on an off when Spanning Tree is active and an access point (7055, 7363, 7372, 7962) is connected? We have found this in several properties now with very similar configurations but have not been able to determine a cause. All of our hotels use Procurve switches at the edge (2910al-PoE or 2520-8G-PoE), all participate in spanning tree, but we only observe the flapping on about 1% of switchports. Of course, 1% for us means that 10-50 guests are getting knocked off the network regularly, so it is a bit of an issue (some ports have 200-300 state transitions *per day*.
We have verified that the configurations on the ports that have the problem match the ports that do not with regard to BPDU filtering, root-guard, etc. We do not believe that it is a deliberate attack because it is the same access points that have chronic issues, whereas the other 99% never do.
Any ideas?
17 REPLIES 17
ali_jaber
use pakedge switches.. go to pakedge.com
bill_burns_6069
Contributor III
Don't know why I never saw this thread before.
I had a similar issue between Ruckus APs (on a controller) and cisco switches.
There was spanning-tree instability in the network due to a firmware issue in a non-cisco-switch.
Ruckus APs meshed together, and passed BPDUs over the meshed connections, magnifying the original problem, causing wired ports to become spanning-tree blocked and generally screwing up the wired network.
After disabling mesh on all non-mesh APs and hard-coding mesh-root APs to the "root" role, the problem did not re-occur.
Apparently, the problem would have had to be triggered by some non-ruckus device but before mesh was disabled (except for areas where it was required and where it could not cause a loop) the mesh feature represented a serious vulnerability to the network.
liam_henry
Want to Pass HPE6-A42 exam in first attempt? Pass your Implementing Aruba WLAN (IAW) 8 HPE Aruba Certified certification exam with HP HPE6-A42 braindumps questions answers of Braindumps4IT. Your Implementing Aruba WLAN (IAW) 8 success is guaranteed with our 100% money back guarantee. We have updated HPE6-A42 dumps questions and providing with HP HPE Aruba Certified exam passing assurance.
