Hi there Diego and thanks for the advice. OK sounds sensible to add Ruckus downstairs in basement and disable wireless on Cisco. This should help roaming and stop us all needing to constantly turn wifi on/off on our iPhones. I'll do that. Conveniently brings my total APs to 5 which is allowed under the Ruskus basic licence.
It's a big ridiculously over-engineered home, and both myself and my wife run our businesses from home with a shared home network. Wi-fi doesn't go well from room to room due to reinforced concrete walls,.
I also have limited bandwidth resource (due to IP cams , internet tv etc) and don't want to further strain this. I believe a ZD will help me better manage this (and have ordered a ZD1200 already so want to use this). I don't want too many more APs as all of my 24 Ethernet ports are spoken for and I don't want more switching layers to strain bandwidth.
I don't really understand how the ZD licence works (can someone please answer my licence question below). I don't mind one off investment but hate committing to subscription plans.
I also can't run new network cable around the place as we extensively renovated 10 years ago and added Ethernet ports around the house and I'm not doing this again. Certainly cant do wire runs to the ceiling. The cost of running neat cabling in house or into garden far outweighs buying a good long range APs as electricians charge a fortune where I live.
My remaining questions:
- Would I be better to use some outdoor Ruckus APs inside my house, because the outdoor APs can take external antennae and may be able to reach my external IP cams more effectively. If so which ones and what antennae are recommended for best range?
- My ZD 1200 comes with 5 free licences which last a year. I understand that if my system is stable I don't need to pay to renew the licence and will just forego updates. Would this be the case if I buy a 6th licence - would I be compelled to renew licence 6 each year?.
- Someone advised me against the X10 range and suggested I go with the 700 instead - what would you advise? Both are within budget. Is the 700 better at roaming between zones? Would there be a difference in range (important to me as my house is built of reinforced concrete which results in a huge amount of WIFI signal attenuation.
- Finally, I assume "unleashed" means Ruckus APs that work without ZD and regular ZoneFlex APs work with the ZD, right?
Money isn't really so much of an issue. Our network has been driving me and my family potty for years and I will gladly pay to have a really good solution.
Many thanks in advance for help! Peter
