01-19-2022 11:27 AM
I was hoping to change the default vlan on some of my AP's that have cameras directly connected to them but as I've seen in other posts this isn't available at least in the unleashed version I'm using (200.7)
But I've figured out if I login to the individual AP's I can change this via the rkscli like this
set interface eth0 type vlan-trunk untag 10
set interface eth1 type vlan-trunk untag 10
Is there a way I can save this change? Otherwise I loose it every time the AP reboots. Or does anyone have any other bright ideas on how to do this. I was hoping to avoid having to put switches at these locations just to do vlan tagging.
I've got a combination of R600s, R610s & a T300 so upgrading unleashed versions isn't an option at this stage.
01-19-2022 01:28 PM
Management VLAN tagging is not supported on 200.7.
And looking at the APs models, I don't think you can upgrade to higher versions.
01-21-2022 12:47 AM
Is there any way I can save the commands I run on the indivdual AP's so they are applied every time they are booted up?
01-21-2022 05:00 AM
@david_hunt scripting or automating this within the AP is not possible.
