Rukus heartbeat loss
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-28-2023 08:19 PM
I have two rukus access points and every twelve hours I get a heartbeat loss message. I have restarted and unplugged my system several times and updated firmware. None of this has resolved the issues. Can someone help? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2023 07:19 PM
Hi @Tspilinek
Heartbeat loss occurs when there is a communication issue between the AP and controller.
Is this happening for all the APs?
Is this happening at a specific time?
If yes, can you login to the AP at the time of issue and check the below details?
a. Ping the controller and see if the response is fine.
b. AP is not rebooting.
c. AP is still connected to the controller from the command "get scg" (If SZ\vSZ) or "get director" (If ZD)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2023 08:06 PM
Hello. Yes this is happening to all AP at the same time. Every 12 hours exactly. I pinged and everything is fine. What is the controller? Is that the switch?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2023 08:26 PM
Hi @Tspilinek
Are you using Zone director, Smartzone or Unleashed setup?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-30-2023 08:37 PM
I am not sure what you mean. I have had this set up for four years and this just started here in the last two weeks with the heartbeat message. I use the rukus unleashed app and the web unleashed.
