Ruckuss P300 compare with Huawei AP8150
seckin_onder
Hi
I am undecided between two antennas.
Ruckuss p300 difference between Huawei AP8150.
Which antenna is better quality ?
Which antenna package loss less?
5 REPLIES 5
Esteemed Contributor II
After provisioning your P300 bridges, did you configure the Distance between them?
From Configuration -> Wireless -> Radio 5G page, click Edit Advanced Settings.
Set the approximate Distance (in Km), where the default is 3Km.  If you have only 120 meters, use 1 Km setting.
Click Update Settings to confirm your changes.  Do this on both sides, as Distance field affects timing.  You might
get better than 285 Mbps throughput.
