Ruckus r510 slave is offline after firmware update
Hello I have two APs. There was a power outage and then when power was back the APs did a firmware upgrade and the slave is offline on the unleashed app. Tried power cycle and it still doesn’t help. Both Power and Ctl are flashing slow.
7 REPLIES 7
Hi Reshma,
If AP is showing stable green power status, this means it got an IP from the wired network.
Run a IP scan or check the DHCP server lease table to find out the APs IP and then SSH into it.
If you are not sure, feel free to open a support case.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
I got it working. Here's how I went about it
1. SSH to slave AP
2. Ping master from slave.
3. "get director". You can verify two things from this a) if the the zone director IP is configured correctly and b) the state of the slave AP. I noticed the slave was in state SULKING which meant it had maxed out its pings to the zone director. This verified that the zone director wasn't set correctly.
4. set director ip <IP_ADDRESS_OF_ZD>
5. Reboot.
I requested "get director" output to confirm the AP state and IP details.
I can see you seems modified the comments but old comment (email notification) shows the same, AP is in sulking state and no IP address in primary and secondary.
Glad to know that you were able to fix it! Well done!
Syamantak Omer
