08-05-2019 12:36 AM
Hi All,
Recently I’ve setup different VLANs on my network and would like to split internal and guest WLANs to two different VLANs.
Ruckus ZoneDirector 3000 with ZoneFlex 7363 APs. Layer 3 switch does my routing, I’ve setup VLANs on my switches with correct gateway and IP Helper (I can connect to different VLANs and get an IP address from DHCP server and access the Internet). I would like to use VLAN 20 for internal laptops and VLAN 30 for guests. But I am having a lot of problems and hope that someone can point me in the right direction.
I have tried different settings combinations but my Zonedirector just cannot see any of my APs. Quick configuration overview:
Three VLANs – 10 (PCS), 20 (Internal Wireless), 30 (Guest Wireless).
On the controller:
Configure – System – Set an IP address for Zonedirector on VLAN 10 with correct Gateway and DNS, Access VLAN 1 (if I set an IP from VLAN 20 and/or set Access VLAN to anything apart from VLAN 1 – Zonedirector becomes inaccessible), port on the switch that Zonedirector connected to is set to VLAN 10.
Configure – WLANs -2 WLANs. Internal set NO to Isolate traffic, Access VLAN 20. Guest set NO to Isolate traffic, Access VLAN 30.
Configure – Access Points – All of previously (connected before I’ve set up VLANs) connected APs are showing. Access Point Group – just one group with all APs. In Port Setting option – set LAN3 connection to “Trunk Port” with Untag ID set to 1.
Monitor – Access Points- All Access Points show as Disconnected.
Ports on the switch that APs connected to set to Trunk, with VLAN 1 – Untagged; VLAN 10, 20 and 30 – Trunk.
I would really appreciate if someone can point me in the right direction. Thanks.
08-05-2019 01:16 PM
08-21-2019 12:59 AM
