Ruckus T610s issue
HEINHTETWIN
Hello everyone,
I have login problem of my Ruckus T610S AP.
AP is already power ON.
PWR & CTL LEDs are slow blinking once by once.
I can ping to the AP default IP address and get reply.
But I can't web access, ssh & telnet to configure.
How can I fix it?
Please help me to fix this issue. Thanks.
1 REPLY 1
sagar_kuber
RUCKUS Team Member
Perform hard reset using below method and then try accessing the AP via SSH/WebUI.
To hard reset a Ruckus access point (AP), you can try these steps:
  1. Identify the type of AP model
  2. Find a paper clip or the clip that came with the AP
  3. Ensure the AP is powered on
  4. Locate the Reset or FD button
  5. Press and hold the button for 10 seconds
  6. Release the button and allow the AP to reboot
The AP should not reboot while the button is being held down. Once the button is released, the AP should reboot, indicating that the factory reset was successful.
https://support.ruckuswireless.com/articles/000012418
Sagar Kuber
Sr. Technical Support Engineer
