Zvii,
In the Unleashed GUI, you can click on the access points tab, and then select either the summary icon on the left to make global changes to all access points, or select an individual AP to change settings on that particular one. Once you select it, click edit above the list. You can then adjust the tx power for the 2.4 and 5 GHz radios separately.
