12-13-2021 11:34 AM
Hello, I have a new zone director 1200 because my old zd is was damaged and it replaced. And now I have 4 AP 7372 in my new ZD I can't seen, i think is because it has old version of firmware.
Is there a way that I can see them on the controller?
12-13-2021 12:35 PM
Hi Kelvin,
just look for a firmware that runs on zd1200 and supports your 7372.
Best regards
Harald
12-13-2021 01:24 PM
Looks like the new ZD is running a lot *newer* firmware then your old ZD. You will have to downgrade the ZD to a perhaps a 10.1.X.X.X software version. I would consider retiring those AP's. Especially if your clients now support Wifi 6 or even 802.11ac . 7372's are very good AP's for Dual Band N, but security and performance moves on,
12-13-2021 06:05 PM
These AP's (ZF7372) are not supported on ZD code 10.2+ hence they will never work on any of those upper version. The maximum supported code for these AP's are 10.1.2.x where you can manage all below AP's. Please keep in mind if you go for a downgrade the existing configuration would wipe and go to factory default.
C110 E510
H320 T300
H500 T300e
H510 T301n
R300 T301s
R310 T310c
R500 T310d
R510 T310n
R600 T310s
R610 T610
R700 T610s
R710 T710
R720 T710s
R730* ZF7781CM
ZF7055 ZF7782
ZF7352 ZF7782-E
ZF7372 ZF7782-N
ZF7372-E ZF7782-S
ZF7982
Best Regards
Vinee
12-14-2021 04:24 AM
Thank you very much for all your comments, I will consider changing those APS
