Radio stops transmitting
I have an Zonedirector 1000 along with some 7942 APs.
We have noticed some issues where the radio in the AP simply dies.
It stops transmitting (it is online in the zonedirector) but it does not show up on the insidder scan.
Power cycle the AP and it start transmitting Again.
This behaviour makes it very difficult to troubleshoot since the ZD states its online.
1 REPLY 1
keith_redfield
Valued Contributor II
If you're not already running the latest ZoneFlex release for the ZD1000 I'd recommend upgrading. https://support.ruckuswireless.com/pr...
If you are and you have an active support contract, then it's probably best to open a support case.
