Showing results forย
Search instead forย
Did you mean:ย
R730 negotiating 100M no matter what I do
I've got a brand new batch of about 20 R730 APs. They're all connected to Cisco 2960X PoE+ Switchgear.
I don't know if I have a power issue or LLDP issue. but all of them running any version of the firmware with or without a controller etc.
They all are negotiating 100Mb max and I can't even set the speed to 100 through the CMD.
Haaaaaaalp!!
19 REPLIES 19
Hi Ray,
In that case you may need to follow what I have suggested in my first comment.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Yes we are going to start with attempting PoE injection for our power feed.
Hi everyone, update on this, I've completed a packet capture for one of the trouble APs on start up. Please see a breakdown of the LLDP packet below ->
Frame 6: 160 bytes on wire (1280 bits), 160 bytes captured (1280 bits) on interface \Device\NPF_{CC6F43DD-B306-4894-A15E-51A78BC9AB47}, id 0
Ethernet II, Src: 70:ca:97:2f:f2:00 (70:ca:97:2f:f2:00), Dst: LLDP_Multicast (01:80:c2:00:00:0e)
Link Layer Discovery Protocol
    Chassis Subtype = MAC address, Id: 70:ca:97:2f:f2:00
        0000 001. .... .... = TLV Type: Chassis Id (1)
        .... ...0 0000 0111 = TLV Length: 7
        Chassis Id Subtype: MAC address (4)
        Chassis Id: 70:ca:97:2f:f2:00 (70:ca:97:2f:f2:00)
    Port Subtype = MAC address, Id: 70:ca:97:2f:f2:00
        0000 010. .... .... = TLV Type: Port Id (2)
        Port Id Subtype: MAC address (3)
        Port Id: 70:ca:97:2f:f2:00 (70:ca:97:2f:f2:00)
    Time To Live = 120 sec
        0000 011. .... .... = TLV Type: Time to Live (3)
        .... ...0 0000 0010 = TLV Length: 2
        Seconds: 120
    System Name = AP04
        0000 101. .... .... = TLV Type: System Name (5)
        .... ...0 0000 0100 = TLV Length: 4
        System Name: AP04
    System Description = Ruckus R730 Multimedia Hotzone Wireless AP/SW Version: 5.1.2.0.373
        0000 110. .... .... = TLV Type: System Description (6)
        .... ...0 0100 0010 = TLV Length: 66
        System Description: Ruckus R730 Multimedia Hotzone Wireless AP/SW Version: 5.1.2.0.373
    Capabilities
        0000 111. .... .... = TLV Type: System Capabilities (7)
        Capabilities: 0x001c
        Enabled Capabilities: 0x001c
    Management Address
        0001 000. .... .... = TLV Type: Management Address (8)
        .... ...0 0000 1100 = TLV Length: 12
        Address String Length: 5
        Address Subtype: IPv4 (1)
        Management Address: 10.0.104.48
        Interface Subtype: Unknown (1)
        Interface Number: 0
        OID String Length: 0
    Port Description = eth1
        0000 100. .... .... = TLV Type: Port Description (4)
        Port Description: eth1
    Ieee 802.3 - Link Aggregation
        1111 111. .... .... = TLV Type: Organization Specific (127)
        .... ...0 0000 1001 = TLV Length: 9
        Organization Unique Code: 00:12:0f (Ieee 802.3)
        IEEE 802.3 Subtype: Link Aggregation (0x03)
        Aggregation Status: 0x01
        Aggregated Port Id: 0
    Ieee 802.3 - MAC/PHY Configuration/Status
        IEEE 802.3 Subtype: MAC/PHY Configuration/Status (0x01)
        Auto-Negotiation Support/Status: 0x03
        PMD Auto-Negotiation Advertised Capability: 0x84c1
        Same in inverse (wrong) bitorder
        Operational MAU Type: 100BaseTXFD - 2 pair category 5 UTP, full duplex mode (0x0010)
    End of LLDPDU
        0000 000. .... .... = TLV Type: End of LLDPDU (0)
        .... ...0 0000 0000 = TLV Length: 0
needs 2 more pair to work.
I'm totally willing to except that, however it's every R730 in the building that's doing this and all other AP models are negotiating full 1000 full duplex... unless my R730's somehow all got connected to 2 pair wires which would be horrific coincidence. There's 25 of them throughout the building on roughly 6 different switch stacks.
