11-26-2021 06:39 AM
Hello, I have a problem with the power on the Ruckus Ap R710, when I connect it to the power, the led of power blinks and the others led dont start. I testing with a switch poe, poe inyector and power adapter, with all of them the result is the same.
11-26-2021 06:42 AM
Hi Kelvin,
A flashing green Power LED means the AP doesn't have an assigned IP address.
Connect to the AP on it's default IP and set a static IP or connect a DHCP server and you should be good to go.
Best,
Darrel.
12-06-2021 05:43 AM
I made all of this tests, and the result is the same. I think that the OS is corrupted because is not booting correctly or is someting wrong with the power...
12-06-2021 06:10 AM
@kelvin_rodriguez
Hi Kelvin, if you are the original purchaser of the R710 then I would advise you contact Ruckus Support to raise a case. https://support.ruckuswireless.com/
Ruckus indoor Access Points have a Limited Lifetime Warranty.
Best,
Darrel.
12-06-2021 07:20 AM
Sure,
I will do it
Thank's a lot
