R710 in Configure.Me-XXXXXX mode
I have an R710 in Configure.Me-XXXXXX mode.  It was connected to a SmartZone 100 controller and has since been removed from the controller.
I can connect to it with the Configure.Me SSID and the S/N of the unit.  The IP of the unit is 10.154.231.125 as it should be, and I can ping it successfully.  As it used to be on a SmartZone, I suspect http and https are disabled.  I also cannot connect to it via SSH.
I can also connect and ping it on the POE port of the device as the unit successfully does get an IP.  Once again here I cannot http, hhtps, or SSH to it.
Firmware is 5.2.xxx
Is there perhaps a way to manually add this unit back into the SmartZone to see if it will connect back?
Thanks for any assistance.
4 REPLIES 4
