R710 ZD Managed corrupt firmware? (can't connect with ssh or http(s)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-10-2020 04:08 AM
I've bought an 2nd hand Ruckus R710, which I cannot access.
I've reset it multiple times with the reset button on the back.
After reset the pwr led goes from red to solid green.
At that point I can ping it on 192.168.0.1 but there is not webinterface on port 80 or 443.
Trying to ssh to it I only get an connection refused message.
I can see that it broadcasts the wireless network island-xxxx
But I can't connect to it. I've tried the following passwords:
sp-admin
ruckus-sp-admin
ruckus-
Is the firmware corrupted? is there anything else I can do to connect to it?
I guess my next step is to contact the original owner to see if he/she can do an RMA?
I want to run this with standalone unleashed.
Thanks, in advance,
/J
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2021 05:43 AM
Same problem for me. I see the WiFi "Configure.Mexxx" but no luck, phone app says I am connected to the Wifi but hit the Start button and it fails with a message that says Unable to fetch default
configuration from the AP.
Did someone brick this? Can I install the Standalone firmware or a new Unleashed version from the USB on the R710 or is the only want to upgrade to use the CLI or the web administration on the R710 to upgrade the firmware?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2021 05:45 AM
message that says Unable to fetch default configuration from the AP.
