โ09-12-2024 12:27 PM
I have 2 R710's in my network. Both home run back to the core switch.
For some reason the 5GHz keeps randomly disapearing (at least it appears to be random).
Firmware is on the latest version (checked it just this morning) on both APs.
FW: 200.15.2.212.14
Powered by DC adapter (not poe)
I know this isn't alot of info, but I'm not really sure what all to provide to help troubleshoot this.
โ09-13-2024 05:55 AM - edited โ09-13-2024 11:33 AM
Check your diagnostic logs. You should see if the AP is detecting interference on the DFS channel and swapping to a new one. When that happens the AP must (by law) wait and ensure the channel is not being used by military/weather radar. The byproduct of this is the channel disappearing for a certain amount of time. If you see that happening, you need to tell the controller to not use the problematic channels.
โ09-13-2024 12:18 PM
Thanks. I went into the support info log.
searched for DFS and found a few
DFS wait set for channel xxx
I've now disabled all the channels I found.
Will this in theory keep me more stable? Or does it randomly do the DFS check on every channel no matter what? You said it's detecting interference, but the log entry didn't APPEAR to indicate that's what triggered it to do this wait.
Basically just checked that I've interpeted it correct, and checked the correct log.
โ09-15-2024 11:02 AM
If you donโt want a random disconnection you need to just disable all DFS channels. Thatโs the price you pay to use the channels unfortunately. The chance of losing wifi becomes less likely when you have multiple APs (as theyโll be on different channels) so thatโs another option.
