R710 AP image for vSZ carrier
randy_rosario
Where to download or get the AP image for R710 to be recognize by vSZ carrier?
33 REPLIES 33
kieran_oakes
You would need to contact Ruckus Support, I had this exact same issue yesterday and they promptly sent me the correct firmware.
dionis_taveras
Contributor II
The R710 is supported in release version 3.1.1 which can be downloaded from the support website at support.ruckuswireless.com or as mentioned by Kieran, you can contact support and a copy of this image can be sent to you.
Esteemed Contributor II
And here are helpful instructions to connect a new AP to the vSZ / SZ-100 platform.
https://support.ruckuswireless.com/answers/000004230
And the base image firmware (will join either ZD or SCG-200/vSZ/SZ-100 platforms, and auto-upgrade firmware from controller),
is version 100.2.0.0.336:
https://support.ruckuswireless.com/software/760-standalone-ap-software-100-2-0-0-336-r710
