R700 Ceiling Mounting on Slotted Tbar
bobby_wittenber
We've got a silly problem but one folks have probably overcome easily.  We want to ceiling mount a couple of R700 APs on a drop ceiling but the Tbars aren't the typical flat tbars that the standard clips will work with.  The bars are skinny with a slot down the middle of them.  They seem to be called slotted t bars but who knows.  Has any one got a quick solution they can recommend versus just leaving the APs above the ceiling tiles facing down?
3 REPLIES 3
Esteemed Contributor II
Please don't anyone suggest Duct Tape!  =:^O
john_d
Valued Contributor II
Cmon, everyone knows you use 3M Command Strips instead! 🙂
scott_swanson_7
Did you ever find a solution to this?  We have 2 R600's that we need to mount to the same type of ceiling.
I found that Juniper has a bracket specifically for this, but wondering if there is a universal or Ruckus version:
https://www.juniper.net/techpubs/en_US/release-independent/wireless/topics/task/installation/wla532e...
