R510 keeps dropping connections and going offline for few min after latest patch kernel panic
dariusz_basiaga
R510 keeps dropping connections and going offline for few min after latest patch 200.9.10.4.233
2021/04/05  16:19:54
High
Radio [5G] of AP[Downstairs@90:3a:72:11:18:30] is ON
2021/04/05  16:19:54
High
Radio [2.4G] of AP[Downstairs@90:3a:72:11:18:30] is ON
2021/04/05  16:18:49
High
AP[Downstairs@90:3a:72:11:18:30] warm boot successfully,last reboot reason [kernel panic].
2021/04/05  16:18:46
High
AP[Downstairs@90:3a:72:11:18:30] joins with uptime [73] s and last disconnected reason [AP Restart : kernel panic]
2021/04/05  16:16:52
High
Radio [2.4G] of AP[Downstairs@90:3a:72:11:18:30] is OFF
2021/04/05  16:16:43
High
URL Filtering is disabled due to insufficient license
2021/04/05  16:06:11
High
2021/04/05  16:06:11
High
2021/04/05  16:05:59
High
Unleashed network change master role from [Downsta
2021/04/05  16:05:08
High
AP[Upstairs@18:4b:0d:36:16:90] joins with uptime [1303] s and last disconnected reason [Heartbeat Loss]
2021/04/05  16:05:07
High
2021/04/05  16:05:05
High
2 REPLIES 2
Vineet_nejwala
Hi Dariusz,
Greeting from CommScope/Ruckus. As per the issue described you would need to open a support case to enable additional debug on the AP's and isolate the root cause.
1) Please open a new case either from WEB Portal.
https://support.ruckuswireless.com/cases/new
or
2) Please reach out to below and a rep would help you in opening a ticket.
Note : You can provide AP support log and Network topology (switch model and version) where AP's are connected to for initial investigation.
Best Regards
Vineet
We had this issue soms time ago (with another version of the firmware). We were able to solve it by performing a factory reset on the affected access points.
