04-08-2025 08:31 AM
R510 has been reset using reset button. This AC connected to external power source and network cable to computer. I could connect to login webpage and used super/sp-admin. After click on 'Unleash' webpage displays 'Login information is incorrect'.
04-09-2025 10:38 AM
Hi @Kevin4
Could you please try using the default username and passwords one by one provided in the screenshot below?
Let me know how it goes,
04-08-2025 09:39 AM
Hi @Kevin4
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
04-09-2025 10:18 AM
Dear Imran,
it's Lennar Home. I am periodically assisting my fried, who owns this house, with technical issues.
This time everything "magically" turned to unknown stage. So, I am trying to reset APs to default and reconfigure back to what it was. Ruckus ICX 7150-C12P Switch seems to be working - I could connect to console and ran few 'show' commands. I used account that builder left on a sticker in network closet to connect to switch. But I used 'super/sp-admin' for AC and it's according to quick setup guide doc that I found online.
Thanks!
04-09-2025 10:38 AM
Hi @Kevin4
04-09-2025 04:06 PM
Thanks,
definitely will try them all or till first works. I'll post what worked early next week.
