R510 Factory Reset Incomplete or Hung?
brian_hiatt_529
I have a "new to me" R510 access point that I can't seem to get into.
I've done the hold the reset button for over 6 seconds procedure several times now.
If the unit is on my lan via a port on my PoE switch, it gets an IP from my DHCP server, and also sets up the Configure.me-xxxx Wireless lan.
But I can not ssh or get https to respond on the IP issued by my DHCP server.  It does respond to ping though.  I have verified that the IP address I'm pinging has a MAC address that matches the MAC address on the R510's label, so I know I've got the right IP.
If I connect to the Configure.me-xxx SSID with the unit's serial number as the password, it doesn't issue an IP address to my client.
If I bring it up directly connected to my PC using a POE injector, it configures itself with the 192.168.0.1 IP address and using a hard coded 192.168.0.10 address on the PC I can ping it, but again I can't get SSH or https to respond at 192.168.0.1.  Connecting a client to the Configure.Me-xxxx WiFi network works, but the client doesn't get issued an IP address and I can not connect to the unit.
I don't know the history of this unit, nor what firmware level it is running other than it must be some version of Unleashed due to the Configure.Me-xxxx wireless lan it creates.
Are there any other tricks I could try to get this unit to try and respond?
Thanks,
Brian
18 REPLIES 18
Yes, but there is no route to 192.168.0.1/24 from 169.254.10.54/16.  I can't get there.
I don't think Unleashed is passing that IP, it is self assigned APIPA IP by client it self .
To get a route to 192.168.0.1/24, you have to manually configure the IP on your device while you are connected to wireless and then access unleashed.ruckuswireless.com or 192.168.0.1
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
ok, now I see what you're getting at.
Power up using just the POE injector with no ethernet.  I get blinking power and ctl.  Set WiFi adapter to 192.168.0.10/24 manually, set gateway and DNS to 192.168.0.1.  Connect to Configure.Me-29ED40 SSID using serial number as password.
Can not ping 192.168.0.1
DNS times out looking for unleashed.ruckuswireless.com and can't bring it up in a broswer.
Hi Brien,
I think its the time to replace this AP as It could be faulty.
Syamantak Omer
Syamantak Omer
Don't know how this ended, but did you have any luck?
