R500
araba_emile_kon
I am trying to load a firmware 500 version 200.7.10.102.64 but the upgrate interface does not work. How could I load the ap via tftp?
1 ACCEPTED SOLUTION
vijaykuniyal
Internal Employee
Hi @araba_emile_kone,
You can use below commands to upgrade the firmware from cli using TFTP.
#fw set host <TFTP server IP address>
#fw set proto tftp
#fw set port 69
#fw set control <image file name>
#fw update
Once image is update, reboot AP with reboot command.
#reboot
Vijay Kuniyal
Staff Technical Support Engineer
CCNA RnS | CCNA Wireless | RASZA | Meraki CMNO | RACPA
3 REPLIES 3
david_black_594
Contributor III
Have you tried a different browser?  Firefox usually works best with Unleashed.
@david_black_5940365
@araba_emile_kone
Exactly, you need to use firefox.
vijaykuniyal
Internal Employee
#fw set proto tftp
#fw set port 69
#fw update
#reboot
Vijay Kuniyal
Labels
