Problems ZoneFlex 7341
I have in my network 5 ZoneFlex 7341 access points and a controller 1106. One of the access points is tipping my switches and leaving my slow network. When I shot this access point everything back to normal. I already gave a reset and the problem remains. I use the setup in my trunk switches to propagate VLANs. I was suspecting that the problem could be in the trunk settings but the other access points are not having problems. Has anyone had this problem?
Thank you,
Fabiano Santos.
1 REPLY 1
Esteemed Contributor II
Not clear what you ask, but try swapping two APs. If you don't have problems with
another AP in this AP's place, request an RMA of the suspect AP.
