Please recommend a wireless ap (50 people at the same time use)
Now that works well as a wired lan server.
However, using a wireless ap
About 50 people at the same time the user is 2.5Mbit /s
used for watching movies at try (image will be somewhat buffered.)
The actual max speed 100Mbit/ s will must become.
2.4Ghz wifi installed.
About the size of a bus outside the radio range of the 15m.
Two lan ports on the server can also be used in two.
Which product is right for you might ask.
(1) wifi ap if you only use one?
(2) wifi ap if you use two?
Thanks!
4 REPLIES 4
