03-17-2023 12:13 PM
About once every quarter my access points go off. Idk what it’s called but the “central hub” has green lights under “power” and “system”
the lights to where the WAPs connect to the hub aren’t flashing any color. Even after unplugging and plugging them back in. Is this a power issue?
03-17-2023 07:47 PM
Hi @Rynrmrz83
Can you make sure the cable used to connect the AP to switch is not causing any trouble ? What AP model are you using and is it a lennar home ?
https://www.youtube.com/watch?v=z-JjGv0XvRs
Best Regards
Vineet
