Moving into home with existing set up
miguel_infante
We just recently moved into a home where the previous owners had 2 AP's and ethernet switch board installed. I can see the RUCKUS WIFI connection on my phone but it is requiring a username and password which I do not have.
I have pressed the reset button on the main unit but still not able to get the WIFI to reset to its "CONFIGURE_MEXXX" name.
Do the AP's themselves have their own factory reset button?
Thanks!
2 REPLIES 2
sunny_gupta
Contributor II
Yes the APs themselves can be factory reset using a paperclip/pin.  There is a button to press for ~10 seconds while powered on to reset them.
You should then be able to connect to the Configure.Me-XXXXXX network with no password and proceed through the configuration wizard.
hector_sanguine
Just did the same procedure on my AP, no luck. Still present a secures WiFi and ask for password. Any ideas??
