Maxumum transmission range for Ruckus T710 outdoor AP
carlos_adrian_m
I would like to know the maximum distance a Rackus t710 outdoor AP can transmit and have devices like phones connectedand running properly in a clear line of site environment
4 REPLIES 4
gupta_pallapot1
Devices like phones will have very less range of coverage. Let's say T710 has enough coverage to reach the phone at the same time the phone should also be able to reach T710 for a proper connection. You can check with your local SE regrading T710 maximum distance as it depends also depends on country code / transmit power
mustafiz_rahman
Hi
This is not the proper answer. Company should provide chart and lab result regarding the mobile device range issue  as whole world is crying for wi-fi high speed internet connection.
mustafiz_rahman
Hi
As a WISP consultant vendor should concluded and published the standard chat and reports. Then it will be helpful for network specialist to select the equipments.
hyosang_choi
Valued Contributor
Generally, ap with omni-pattern send signal to about 80m ~ 120m.
