01-18-2022 12:57 AM
Hello everyone,
i am looking for a compatible Power Plug which can be used in a Ruckus Environment.
Already tried one from SmartLife but it will not work.
Does anyone have a recommendation?
Regards
Peter
01-18-2022 01:03 AM
Hi Peter, I have previously used a Tapo (part of TP-Link) smart Wi-Fi power-plug. https://www.tapo.com/uk/product/smart-plug/tapo-p100/
The Tapo device connected and worked fine to my Ruckus network ... but had VERY poor Wi-Fi signal sensitivity. At approx 10 metres from the AP and behind a desk it had an intermittent signal.
However I have a colleague with a Ruckus network in his business and he uses them extensively and is very pleased with their performance.
I would recommend creating a new WLAN specifically for the Power Plug devices, so you can disable many of the 'smart' Wi-Fi features that are enabled as standard and hugely benefit 'standard' devices such as smart phones, laptops, etc.
Please note; the above recommendation is my personal view and not the official response of CommScope or Ruckus Networks.
I hope that helps,
Darrel.
