I know the R700 sadly didn't support LACP, but I thought the R710 did?
I followed the instructions that I've seen online:
ruckus(ap-mode)# get power-mode
PoE Configured Mode : AT
Power Consumption Status : 802.3at Switch/Injector
OK
ruckus(ap-mode)# set bond bond0 add eth0
OK
ruckus(ap-mode)# set bond bond0 add eth1
OK
ruckus(ap-mode)# set bond bond0 xmit-hash 1
OK
ruckus(ap-mode)# set bond bond0 lacp-rate 1
OK
However:
ruckus(ap-mode)# get bond
LACP/Bonding is DISABLED.
OK
ruckus(ap-mode)# get bond bond0
OK
ruckus(ap-mode)# set bond bond0 enable
Error: parameter error
Usage:
set bond
{options}
** : bond0, ...
** options:
- enable : R720 Only to enable LACP Mode
- disable : R720 Only to disable LACP Mode
So does the R710 not support LACP and ONLY the R720? https://www.ruckuswireless.com/products/access-points/ruckus-indoor/ruckus-r710 seems to imply that it's supported.
My HPe switch says that both ports are in the Trunk, so I'm assuming LACP is working, but it's disturbing that the AP says disabled?
According to https://www.juniper.net/documentation/en_US/release-independent/nce/topics/example/nce152-example-LA... I should be able to "get bond" on the AP, eg, they have:
rkscli: get bond
Mode: 8023AD
LACP-rate: fast
MII-Mon: 100 (ms)
Xmit-Hash: layer3+4
Slaves: 2
Slave-0: eth0, ACTIVE, UP, link-fail-count: 0
Slave-1: eth1, ACTIVE, UP, link-fail-count: 0
OK
Both ports are up:
ruckus(ap-mode)# get eth
Port Interface 802.1X Logical Link Physical Link Label
0 eth0 None Up Up 1000Mbps full 10/100/1000 PoE
1 eth1 None Up Up 1000Mbps full 10/100/1000
Note: Read Port#N as N+1, if you are referring this CLI output with AP's "Configure :: Ethernet Ports" UI Page.
Is this a bug or is LACP really not working?
Thanks!
