LACP on R710?
I know the R700 sadly didn't support LACP, but I thought the R710 did?
I followed the instructions that I've seen online:
ruckus(ap-mode)# get power-mode
PoE Configured Mode      : AT
Power Consumption Status : 802.3at Switch/Injector
OK
ruckus(ap-mode)# set bond bond0 add eth0
OK
ruckus(ap-mode)# set bond bond0 add eth1
OK
ruckus(ap-mode)# set bond bond0 xmit-hash 1
OK
ruckus(ap-mode)# set bond bond0 lacp-rate 1
OK
However:
ruckus(ap-mode)# get bond
LACP/Bonding is DISABLED.
OK
ruckus(ap-mode)# get bond bond0
OK
ruckus(ap-mode)# set bond bond0 enable
Error: parameter error
Usage:
set bond {options}
** : bond0, ...
** options:
    - enable  : R720 Only to enable LACP Mode
    - disable : R720 Only to disable LACP Mode
So does the R710 not support LACP and ONLY the R720? https://www.ruckuswireless.com/products/access-points/ruckus-indoor/ruckus-r710  seems to imply that it's supported.
My HPe switch says that both ports are in the Trunk, so I'm assuming LACP is working, but it's disturbing that the AP says disabled?
According to https://www.juniper.net/documentation/en_US/release-independent/nce/topics/example/nce152-example-LA... I should be able to "get bond" on the AP, eg, they have:
rkscli: get bond
        Mode:           8023AD
        LACP-rate:      fast
        MII-Mon:        100 (ms)
        Xmit-Hash:      layer3+4
        Slaves:         2
        Slave-0:        eth0, ACTIVE, UP, link-fail-count: 0
        Slave-1:        eth1, ACTIVE, UP, link-fail-count: 0
OK
Both ports are up:
ruckus(ap-mode)# get eth
Port  Interface  802.1X  Logical Link  Physical Link      Label
0     eth0       None    Up            Up 1000Mbps full   10/100/1000 PoE
1     eth1       None    Up            Up 1000Mbps full   10/100/1000
Note: Read Port#N as N+1, if you are referring this CLI output with AP's "Configure :: Ethernet Ports" UI Page.
Is this a bug or is LACP really not working?
Thanks!
16 REPLIES 16
israr_ahmed_93c
hi ,
Please WhatsApp me on +919985563228
thank you
Please open a case. It is not appropriate and Ruckus does not endorse for members to "WeChat" or "WhatsApp" or other PC-control type program interaction between unverified persons.  Please open a ticket with our Tech Support, and share your information above, so we can assist you properly.  Thanks!
hi Guys
I have exactly the same problem, is there a solution regarding LACP?
Sorry for my bad English, I live in Germany and my english is not special.
hi Guys
Esteemed Contributor II
Es ist sehr gut Hans.
Have you tried the information from here?
We have a knowledge base article 3118 regarding LACP for link aggregation of two Eth ports on 802.11ac APs (ie R710).
https://support.ruckuswireless.com/articles/000003118
You need at least 802.3at PoE+ or a passive PoE injector capable of 20W.
