Irregular ping to AP
andrea_marini_7
Hi everyone!
We have built an Unleashed network inside a storing facility recently and everything seems fine, except that sometimes the network slows down. Trying to do some troubleshooting, we found out that when connected to an AP, pinging that same AP gives irregular and quite erratic results. Most of the times, the replies are under 30 ms but there are various irregular spikes that go up to 400 and even 600 ms. This seems completely random, as we didn't move the client, the AP or anything between the two. The wired network seems fine as well.
Do anyone have suggestions on what to troubleshoot further in order to understand what's the cause of this behavior?
4 REPLIES 4
WiFiGuy
RUCKUS Team Member
Do all the AP have a home run to the switch or are you using mesh connections for some of the AP?
Consider using WireShark to capture traffic during the slow time to see what is happening on the network?
Consider Checking the switches give you indication of port utilization?
andrea_marini_7
All the APs have cables running to the switch, when connected to the wired network the ping is perfect at a constant >1 ms, so the issue must be on the wireless communication.
I didn't think about WireShark, I'll look into it. Thanks a lot.
monnat_systems
Valued Contributor II
in my experience.. such symptoms point to presence of some level of RF interference in the network... either AP is changing channel regularly to avoid interference or RF outthere is too congested to give you smooth connection over wifi
Is irregular and quite erratic results on pings giving production/business issue or problems?
andrea_marini_7
The AP seems to be stable on the same channel, we haven't done a perfect job managing channels to be honest but there shouldn't be much cross-channel interference. It might have something to do with the items stored or other RF interferences such as DECT stations and similar.
The results on the pings aren't giving any issue per se, but people working in the facility complain about a general slowness of the WiFi network.
