06-24-2026 06:30 PM
I'm trying to determine whether this is a PC issue or a network issue.
Does this sound more like an issue with the apartment's managed network/Ruckus infrastructure, or is there anything else on my PC that could still cause this? Any additional diagnostics you'd recommend?
07-23-2026 12:45 AM
Hi BrandonW55,
I would check on the device where Interface 100.72.0.1 is configured, as the PC is directly connected to AP (Hospitality AP).
Test by directly connecting to the Switch where this AP is connected with same VLAN and see if you see the same behavior or try giving another VLAN (Access port) and see if does any change.
-HTH
