Initial R720 setup Cant Connect https http or ssh
adi_piatno
I'm configuring an R720, going through the initial setup. I factory reset the device and I can ping the default IP 192.168.0.1, however I cannot access it via the web or through SSH. There's a strong possibility that this device was once configured with a ZoneDirector, I've read that might be the problem. I'm new to Rukus and I just want to know if there's anything I can do in this situation without going through ZoneDirector, which I've never used before.
5 REPLIES 5
babar_gondal
Hi Adi,
if you set your AP to factory default you can SSH into it via default username and password. i.e. super and sp-admin.
if it not set to factory default. you can SSH into it via username and password you configured for in zone configuration for AP management
for http / https access you have to enable it after SSH into to the AP.
rkscli: set http
Usage:
        set http {enable|disable}
        set https {enable|disable}
Hope it will fix your issue.
Ta,
Babar
adi_piatno
Hi Babar,
Thank you answer, but I reset the factory default by pressing the reset button 10 seconds, but to ping 192.168.0.1 is ok.
whereas I try to ssh it can't
Thank You
Adi
Friend good morning, Could you solve the problem? What should I do? thank you
Friend good morning, Could you solve the problem? It turns out that I have the same situation that you mention and I would like to know if you could find a solution. thank you
