I cannot pair 2 ZoneFlex P300 Wireless Bridge,
I cannot pair 2 ZoneFlex P300 Wireless Bridge, have completed all the config but the wireless status on the non-root bridge says the wireless is disabled
2 REPLIES 2
Hi Alipate,
- could you please verify all LEDs are Green and power is ON?
- Also check you have same SSID and passphrase on both units.
- what is the range between both links? what type of antennas do they have?
- Please, go to Status --> Wireless , and in Site Survey side click on "ReScan". Do this on the Root Bridge (RB) and in the Non Root Bridge (NRB).
- After checking all the above, connect to CLI and give us the output of this command, for RB and NRB,
get scanresults wifi1
get mesh
Thanks.
David.
sanjay_kumar
Hi Alipate,
If the above steps are followed and still have the issue, try setting the Root as Gateway on the Non root and check. I had this issue in lab setup and working on Gateway worked for me.
Sanjay Kumar
