Hydrawise Irrigations system
I have a client where the landscaper just installed a Hunter Hydrawise irrigation system.  It will not grab a DHCP address right away.  After about 30 mins - 3hours it will grab one and then fall off.  If we hook the irrigation system to a mobile hot spot it connects right away.  All other devices at the Hydrawise location connect fine.  We have a ZD1200 with R610 access points.  Anyone run into this before or have some suggestions on what to try?
2 REPLIES 2
WOW! A real challenge.
What platform are you using to monitor/ administrate your APs?
Derp Zd1200, Have you used Wireshark to break down your DHCP responses?
