A hard reset was done to a Zone flex 7962 AP using the external pin hole to revert to Factory set up.
AP is powered but does not rediscover the ZD. The original FW was 9.4.
After a firmware upgrade to 9.6.0.267 to match a working AP and being directly connected to the ZD1100 the zoneflex 7962 AP is unable to connect to the ZD.
the default web access is working.
I was able to ssh in to the AP via the default ip address and manually set the director ip address. Still no joy.
any suggestions ?
