03-23-2021 01:09 PM
I have a number of 7055 Access Points wall mounted in some condos. I can't figure out how to remove these units from their wall plates. It does not appear that there are any Torx Bracket Screws installed.
Any suggestions would be appreciated, so I don't have to destroy my walls to remove these units.
Thanks,
06-18-2024 07:23 AM
There is a little pin hole that has a mount release button in it. I'm not sure exactly where it is on the 7055, but on the R550 it is above the frequency LEDs.
