How can I tell if a client is connected with 5ghz or 2.4ghz and when they roam between them?
kurt_5686453
Note: This topic was created from a reply on the iPad reauthentication issue... topic.
10 REPLIES 10
keith_redfield
Valued Contributor II
Turn logging on (either on the AP or ZD) and you'll see entries like this when a client connects:
Nov 20 05:53:01 RuckusAP daemon.info hostapd: wlan0: STA 5c:96:9d:73:59:9f IEEE 802.11: associated
Nov 20 05:53:01 RuckusAP daemon.info hostapd: wlan0: STA 5c:96:9d:73:59:9f WPA: pairwise key handshake
the wlan0 in this case is my 2.4 radio - if it were wlan8 it would be my 5Ghz
Do we need debug logging enabled for this to work?
dtsblake_588878
Contributor II
I also see in my ZD's dashboard log entries, something like:
2013/11/21 07:54:11 Low guest AP[AP-14194] radio [11a/n] detects User[guest] in WLAN[P-Net] roams from AP[AP-14194]
2013/11/21 07:54:11 Low guest AP[AP-14194] radio [11g/n] detects User[guest] in WLAN[P-Net] roams out to AP[AP-14194]
How can you tell if the user is on 2.4 or 5 from those messages?
