Hidden SSIS's I didn't create showing on scanner
joseph_voldeck
When using a WiFi Scanner for signal issues I am seeing Hidden networks that I didn't create and they are from MY network. What are the hidden network or signals being broadcast from the AP's ? In WiFi Analyzer they show as question marks and show they belong to Ruckus.
Thank you
Joseph
10 REPLIES 10
karl_lavender_7
You have any wireless devices running off it ?  wireless mice etc ?  anything like that might appear.  You could disable any hardware like that and see if the ???? disappears.
joseph_voldeck
Thanks for the reply. Nope let meshow an image that will be better that the way I asked it. This iscoming from the AP's howeverI do have a few WLAN's turned OFF on the ZD I don't know if that is an issue or if this still just brodacast management beacons.Image_ images_messages_5f91c439135b77e2479c9284_67deef4c6afdf083a69283b08f2201e9_RackMultipart20180514986466ikg-2362fced-ba6f-43ad-a33e-36a324537729-1415719544.PNG1526337644Image_ images_messages_5f91c439135b77e2479c9284_fba4ee891ee0cd6a43e2b6cbb96e0ec1_RackMultipart20180514937051kxi-6420af04-8cd1-4269-b2b7-7958033722ef-516655498.PNG1526337704
mitchell_axtell
Contributor II
Do you have mesh enabled?
joseph_voldeck
Yes I do. Is that it!? I tried everything on the controller and totally forgot about that. I cannot check at the moment but what do you think
