H500, R500 and R600
aya_al_jarrah
What is the actual range does ZF H500 ,R500 and R600 covered ?
4 REPLIES 4
seanmuir
Contributor III
This depends heavily on the environment you are ploying the AP's in and the bitrate you are trying to achieve.
aya_al_jarrah
ok ,but could you give me the range in the worst case !!
at what bitrate?
john_d
Valued Contributor II
I've seen my R600 cover 3000 sq ft in a midwest 2-story house with open floorplan construction (30mbit+ everywhere). I've seen the same AP cover less than 4 offices (~400 sq ft) in an office with lots of walls, narrow hallways, and 100+ competing neighbor APs (drops down to under 5mbit at those ranges).
It's a huge range and likely won't help to answer your question! What kind of environment are you deploying in, and what is your goal in terms of the speeds you deliver?
