04-26-2017 02:37 AM
04-26-2017 06:14 AM
04-26-2017 03:19 PM
08-24-2022 11:49 PM - edited 08-25-2022 01:23 AM
I encounter the same issue here with H500 latest firmware
Device Name: RuckusAP
Device Location:
GPS Coordinates:
MAC Address: 94:F6:65:3B:7E:20
Serial Number: 161594601169
Software Version: 104.0.0.0.1347
The switch connected is Aruba 2930f with
# sh vlans ports 20
Status and Counters - VLAN Information - for ports 20
VLAN ID Name | Status Voice Jumbo
40 USR | Port-based No No
70 GUEST-WIFI | Port-based No No
100 MGMT | Port-based No No
my H500 mgmt ip vlan100 is 10.0.100.236
2930f ip 10.0.100.220
PROBLEMS:
1. from switch, I can't ping AP and vice versa
2. port 5 WAN port always untick, although I tick back and set vlan100
when I click Update, it will revert to untick again
3. need to use Chrome instead of Opera when connect to GUI after factory reset. Otherwise I can't connect to GUI
I don't have this problem with my other AP
-Cambium E410
-Cisco 1832i
-Aruba AP-207
Could Ruckus ask Indonesia Disti to RMA my AP?
Please help
08-25-2022 04:09 PM
UPDATE:
I can't edit my post so I just make new reply
1. problem #1 solved, need to replace the cable because the head is loose
need to test dot1x with this model
It seem, I can't test MAC authentication here, but only dot1x.
I can't set delimiter or uppercase of RADIUS username
