Hi Resmus,
First of all, a Ruckus AP comes in two different country wise product code,
1- Country specific where country code is fixed and cannot be changed. Product name will look like below. Here AP model is H510 and its product country code is US which is fixed and cannot be changed.
xxx-H510-UK00 xxxxxxxxxxxx
2- APs which can be used World Wide and their country code can be changed. For example, refer below. Here it is a H510 model and product country code is WW (World Wide) so you can change the country code depending upon which country you are going to use the AP.
xxx-H510-WW00 xxxxxxxxxxxx
To check if your AP is fixed to a country code or not, run below command and look for "
Fixed Ctry Code:" in the output. If it says "
no" means AP is for WW use and if it is set to "
yes" then AP can only be used as per it's product country code.
get boarddataExample output:
magic: xxxxxxxx
cksum: e47
rev: 5.4
Serial#: xxxxxxxxxxxx
Customer ID: 4bss
Model: T310D
V54 Board Type: GD56
V54 Board Class: QCA_ARM
Random#: 3934 3732 3436 3439 3764 3032 3062 6561
symimgs: yes
ethport: 1
V54 MAC Address Pool: yes, size 16, base xx:xx:xx:xx:xx:C0
major: 1027
minor: 11
pciId: 0000
wlan0: yes xx:xx:xx:xx:xx:xx
wlan1: yes xx:xx:xx:xx:xx:xx
eth0: yes xx:xx:xx:xx:xx:xx
eth1: yes xx:xx:xx:xx:xx:xx
eth2: - xx:xx:xx:xx:xx:xx
eth3: - xx:xx:xx:xx:xx:xx
eth4: - xx:xx:xx:xx:xx:xx
eth5: - xx:xx:xx:xx:xx:xx
uart0: yes
sysled: no, gpio 0
sysled2: no, gpio 0
sysled3: no, gpio 0
sysled4: no, gpio 0
Fixed Ctry Code: yes
Antenna Info: yes, value 0x00007372
usb installed: yes
Local Bus: disabled
factory: yes, gpio 8
serclk: internal
cpufreq: calculated 0 Hz
sysfreq: calculated 0 Hz
memcap: disabled
watchdg: enabled
FIPS SKU: no
I hope this helps.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
