02-10-2022 06:39 PM
I've had very good experience with the R300, 320, 500 and 550 unleashed. The most I've ever needed was 15 at one location. I have a client who has some R550s and wants to replace their other APs (other brand) with R750s. Do they get POE over the 2.5gbps connector ? I've never worked with anything over 1gps poe.
Also they will probably have about 20 APs in total between the R750's and R550's - any problem with the unleashed running off of one of these as the master in an unleashed config? I heard they used to recommend a director or something once you got to a certain number but also heard that restriction was going away with the new units.
02-10-2022 08:42 PM
Quote below from the unleashed 200.12 release notes.
An Unleashed network can scale up to 128 Access Points and 2,048 concurrent clients in bridge mode (gateway mode supports up to 25 APs and 512 clients).
I have a R750 and the PoE is over the 2.5G port.
