Fixed MAC Address for SSID
marco_eichstet1
Contributor III
i have a ZD with some R500.
I have some wired Clients connected to a Wireless Bridge. Wireless Bridge is connected to one R500.
Everyhting works fine.
There is just one issue.
Within the GUI of my Wireless Bridge i have to set the SSID and the SSID's MAC Address.
If i restart my R500 the SSID sometimes get another MAC and my Bridge is not able to connect anymore.
Is there a way to fix the MAC my R500 is using for a specific SSID?
Thanks!
Kind Regards
Marco
8 REPLIES 8
dionis_taveras
Contributor II
Not a problem for roaming, actually, it is meant to assist roaming. It would be configured under the WLAN configuration. Should be a field right under the SSID field. You would need to be using one of the latest code version, I believe 9.9 and newer support this. Not 100% sure on that as I normally work with the SmartZone software. I would have to verify it.
marco_eichstet1
Contributor III
Assist Roaming? Why is it not enabled / used by default?
Anyway:
Unfortunatelly there is no such option within my ZoneDirector GUI.
dionis_taveras
Contributor II
It's a bit more complicated than that, let's put it that way.  It is a somewhat recent thing and not as easy as it sounds.
Aside from this, I do not know of a way to statically assign the BSSID to an SSID.  I would recommend upgrading the code on the ZD to a newer version in order to use this feature.
marco_eichstet1
Contributor III
ZD Version is up-to-date (9.12.1 build 148).
Maybe there is a CLI command which is know by somebody.
Maybe someone from Ruckus have any idea?
Thanks.
