05-28-2022 08:45 PM
I have two APs connected as a bridge. The local side works great, but once or twice a week the remote side appears to stop communicating on the ethernet port. I can still remotely control the remote AP since it's connected via WiFi, but I can't communicate with anything that is connected to the ethernet port on that AP until I either reboot it or enable/disable the ethernet interface. In the web interface the ethernet port shows that it's connected, but there are no ARP entries for ethernet. I see the following entries in the logs, though I'm not sure if this is helpful:
Nov 5 20:03:21 RuckusWB daemon.notice meshd[730]: uplink(wired=0)=70:00:00:00:30:00(650.0) best_wired=null(0.0) proposed=null( ,0.0,0.0)
Nov 5 20:03:24 RuckusWB user.warn kernel: eth0 athr_gmac_tx_timeout
Nov 5 20:03:29 RuckusWB user.warn kernel: eth0 athr_gmac_tx_timeout
Nov 5 20:03:34 RuckusWB user.warn kernel: eth0 athr_gmac_tx_timeout
Any help is greatly appreciated. Thank you
05-28-2022 11:31 PM
Can you attach the support log from the AP in question when issue occurs ?
Best Regards
Vineet
07-13-2022 11:27 AM
I am having a similar issue, was this issue ever resolved?
